Re: vaccum on my seditment bowl on an H
Posted by Bob M on August 26, 2003 at 19:19:43 from (66.66.126.3):
In Reply to: vaccum on my seditment bowl on an H posted by Chris on August 26, 2003 at 19:09:20:
Chris - That's normal. If the carb bowl is full (so the float needle valve is shut), flow into an empty sediment bulb will range from slow drip to not at all - it's simply the carb float doing it's job.
If you want proof try this: Remove the drain plug from the bottom of the carb bowl, then open the sediment bowl valve. The sediment bulb will fill almost instantly to replace the gas flowing out of the carb drain.
Post A Followup
: Re: Re: vaccum on my seditment bowl on an H
