Re: 606 overheating
Posted by Randy in NE on August 27, 2003 at 04:19:33 from (216.58.237.20):
In Reply to: 606 overheating posted by Bill in Florida on August 26, 2003 at 20:44:47:
You can check for flow in the radiator. With the tractor running, the radiator cap off, and the tractor up to the temp of the thermostat you should be able to see the coolant swirling in the top of the radiator. You need to be careful so as to not burn yourself with the hot coolant. Chances are you may not be able to get it up to operating temp with is just idling with no load. Like Nebaska Cowman said the water pumps are pretty reliable.
Post A Followup
: Re: Re: 606 overheating
