Re: How do you replace an outer axle bearing on a
Posted by Randy in NE on August 27, 2003 at 04:30:51 from (216.58.237.20):
In Reply to: How do you replace an outer axle bearing on a 560 posted by big red 1 on August 26, 2003 at 13:02:12:
I don't own a 560 and am just speaking from general experience/knowledge. The bearings are pressed into the end of the axle tube. You will most likely need to pull the rear axle, pull the axle out of the axle tube, and then you can get at the bearing. On the older letter series tractors you can get to the bull gear retaining bolts by removing the pto. Not sure about the 560. Someone on this board should be able to give you specific instructions. At any rate it is going to take a little work. Remember that safety is priority one.
Post A Followup
: Re: Re: How do you replace an outer axle bearing on a
