Re: 230 Farmall oil levels and types
Posted by Jay on August 27, 2003 at 06:29:41 from (66.231.126.39):
In Reply to: 230 Farmall oil levels and types posted by Bryan on August 26, 2003 at 20:38:56:
The new spec for this is HTF or Hy-Tran. Having said this, I would check w/ your Case/IH dealer. It probably called for 80-90, or 90 when it was new. In terms of viscosity, most hydraulic oils would be about a 75w85 if measured as they do gear lube.
So basically, if you want to use Hy-Tran, you are safe, if you would like something stiffer, check w/ your dealer.
I *think* the check plugs are normally on the side, about 1/3 of the way up.
Post A Followup
: Re: Re: 230 Farmall oil levels and types
