Re: Question on Farmall 200?
Posted by Gary-Miss on August 27, 2003 at 17:35:51 from (205.188.209.140):
In Reply to: Question on Farmall 200? posted by Joe Perkins on August 27, 2003 at 13:07:55:
Your head will work fine. I have gone the full gamut, all the way from the old istillate, low compression pistons to the high altitude pistons.You will have to buy the pistons and sleeves as a set. You will also want to measure the bottom diameter of the old sleeve and make certain the new one has the same diameter (outside diameter. The top will be the same. No problem at all. It will make a big difference. Good luck.
Post A Followup
: Re: Re: Question on Farmall 200?
