Re: what manual do i need?
Posted by Hugh MacKay on August 30, 2003 at 02:47:41 from (216.208.58.123):
In Reply to: what manual do i need? posted by joe on August 29, 2003 at 18:32:27:
Joe: An operator's manual should cover the adjustment of pto. Having said that you will have to be sure the manual you buy covers the pto you have. You could run into the same with service manual. The 300 started out with a planetary type pto and by late 460 and 560 it had changed to clutch type. Lately here on forums we have learned there was an earlier and different clutch type. I'm not sure I am convinced on this one yet. To me the clutch types all look the same. I have seen 350's both ways. I farmed with a 300 planetary and 560 clutch type. The difference is planetary looks about 1 foot square from back, whereas clutch type is smaller and rounded with pto shaft recessed. If you send me an e mail I do have a photo of clutch type, or send a photo of yours.
It is somewhat fuzzy as to just when IH changed these. All 300 have planetary, I have seen 350, 340 and 460 both ways. It is same with 400, 450 and 560. Looks as though there may have been a time frame where you could get either/ or.
Post A Followup
: Re: Re: what manual do i need?
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
