Re: Block Heater for Farmall 400
Posted by 26Red on August 30, 2003 at 22:00:42 from (12.28.105.9):
In Reply to: Block Heater for Farmall 400 posted by Russ Vetter on August 30, 2003 at 18:42:41:
Get a external tank heater and mount it on the carburator side of the engine. Plumb the the heater by running a hose from the temp sensor fitting in the cylinder head. You'll have to add a "t" fitting to retain the temp sensor. Run the other hose from the water jacket drain plug on the side of the engine block (behind the carburator) to the other output of the tank heater.
Post A Followup
: Re: Re: Block Heater for Farmall 400
