Re: 1946 Farmall H question
Posted by CNKS on August 31, 2003 at 14:15:39 from (207.178.96.211):
In Reply to: 1946 Farmall H question posted by Rob from Michigan on August 31, 2003 at 10:43:33:
Since you can take care of the engine, drive it around in all gears and listen for strange noises. The H transmission is very quiet, unlike transmissions in the A and B, the C is also quiet. Another likely problem is the clutch, the hydraulic pump must come out, then it can be replaced without splitting the tractor. It must be split to replace the flywheel, same for the rear crankshaft seal. Seals in transmission and hyd pump often leak, for you, easy to fix, as are the brakes. Make sure the pto is ok if you want to use a bushhog. PTO is not live, meaning it will not turn with the clutch disengaged. Rear axle seals often leak, fairly easy to fix, just takes time. Drive it in 5th and see if the front wheels wobble, this is a common problem due to wear in the upper bolster. Transmission may jump out of 5th due to worn shifter linkage, requiring removal of the trans cover. These problems can occur in most old tractors, depending on what has been fixed, and how long ago. Parts are readily available.
Home
| Forums
Today's Featured Article -
Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
