Re: Re: 450 farmall tractor
Posted by Jimmy King on August 31, 2003 at 16:08:04 from (63.186.40.116):
In Reply to: Re: 450 farmall tractor posted by Jimmy King on August 31, 2003 at 16:01:07:
Rex then I set here and thought about it some more Lever back for gas forward for Diesel because I remembered about all you have to do is bump it with your hand and it will flip forward pull down throttle at same time.
Post A Followup
: Re: Re: Re: 450 farmall tractor
