farmall A pto size
Posted by Peter Hatlestad on August 31, 2003 at 16:49:37 from (152.163.253.102):
I have a '39 Farmall and a '40 Farmall B. I noticed that the PTO shaft for the '39 is at least '1/4 smaller than the '40 B. Was that common? I want to use the '39 to pull an auger to load my bins but it can't run any because the pto shaft is to small.
Is there an adapter or do I have to find a pto shaft from a B or a C to fix this?
Thanks,
Pete
Post A Followup
: Re: farmall A pto size
