Re: 354 Diesel
Posted by JB on August 31, 2003 at 18:32:00 from (24.157.142.242):
In Reply to: 354 Diesel posted by Maury on August 30, 2003 at 15:30:52:
Hi Maury, If you are positive there is fuel to the injectors, is there smoke coming out the rail pipe ?
Had the following happen on a 8 week old B414D, I was baling with it and all of a sudden it made a clattering noise, smoke came out the air breather and it stopped. Luckly it was still under warranty. Problem was key came out of camshaft timing gear. IH had to replace all the pistons, valves and pushrods.
The other major problem we had was on a B434D, going up a hill it suddenly stopped and would not start again. Although there was fuel to the injector pump, there was no fuel to the injectors. Had to replace injector pump.
Good luck with your 354
JB
Post A Followup
: Re: Re: 354 Diesel
