Re: How to get a front wheel off
Posted by Haas on August 31, 2003 at 18:36:13 from (12.65.78.192):
In Reply to: How to get a front wheel off posted by Gary The Rookie Farmer on August 31, 2003 at 06:30:44:
If the other two suggestions don't work, split the nut with a cold chisel. Sometimes you don't have to split the nut completely, just a notch in the side of the hex with the chisel will loosen it up enough to get it off.
Post A Followup
: Re: Re: How to get a front wheel off
