Re: Farmall 140 Clutch Problem!
Posted by Hugh MacKay on August 31, 2003 at 18:58:37 from (209.226.247.187):
In Reply to: Farmall 140 Clutch Problem! posted by JW (NC) on August 31, 2003 at 16:48:09:
JW: As Oars put it just something stuck. Several ways to free it use his solution. Have someone tow you with another vehicle as you hold clutch down and in gear. Lock the brakes, tie the clutch pedal down and use hand crank, starter may even do it.
Long term solution is use the tractor more.
Post A Followup
: Re: Re: Farmall 140 Clutch Problem!
