Re: Farmall 140 Clutch Problem!
Posted by gene b on August 31, 2003 at 19:49:35 from (65.227.11.126):
In Reply to: Farmall 140 Clutch Problem! posted by JW (NC) on August 31, 2003 at 16:48:09:
A bad pilot bearing in the crankshaft will do this also. Just finished one that had that problem. Will the engine start with it in gear and the clutch depressed? Better split and fix that way you will not have any more problems.
Post A Followup
: Re: Re: Farmall 140 Clutch Problem!
