Re: Points and Condenser on M Farmall with Magneto
Posted by Michael Soldan on September 01, 2003 at 17:00:29 from (216.46.130.14):
In Reply to: Points and Condenser on M Farmall with Magneto posted by Pat Bryant on September 01, 2003 at 15:48:28:
Pat, I just did this with my M a few weeks ago and got it running. I think by my experience that if you don't mess with things too much you can unbolt the mag, change the points and bolt it back in. After removing the mag there is the distributor and rotor to pull off. Next there are three screws holding a plate over top of the points and condenser, they can only go back on one way but marking the position of the plate with some yellow crayon will save you twisting and turning the plate till you get it right. I use fine emery cloth doubled over and positioned between the points and rub the cloth back and forth for several minutes..not only does this clean the points but it aligns the surfaces when the emery cloth is removed. I then just put everything back on the tractor as I took it off and the old M fired right up.Don't snap the mag over or don't turn the engine over when the mag is removed and thus it will go back in correctly. If youy have to time it you will find notches on the front crank pulley, there are two ways to time it..TDC or align the notch in the pulley to the mark on the block...the mag should fire as the piston moves from TDC...I've had to do this with the M three or four times in the last few years as I sometimes let it sit for several months..just clean up the points and I'm in business....good luck from Mike in Exeter Ontario
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
