replacing axles seals on super A
Posted by Dave Feldman on September 01, 2003 at 18:19:12 from (12.90.24.229):
I've tried to remove the axle on my super A by removing the inner bearing cap, retainer screw & washer, outer bearing retainer screws, and bottom oil pan. after pounding on the axle flange through a block of wood, axle has moved less than a 1/4". I notice the rear axle drive gear is up against housing. Is there something else i need to do before the axle can be pushed out of the housing? Do I need remove the axle drive gear?
Thanks all you IH fans.
Dave Feldman
D
Post A Followup
: Re: replacing axles seals on super A
