Re: Re: Re: how can you tell if piston/sleves are
Posted by Jailkeeper on September 01, 2003 at 22:46:14 from (216.174.160.141):
In Reply to: Re: Re: how can you tell if piston/sleves are worn posted by Bob Quale on September 01, 2003 at 20:51:41:
Since you've got the head off, take a few valve springs off and try to wiggle the valves in the guides. If you get any side to side movement, the guides are worn. That could be the biggest problem with your oil consumption.
I don't know what the compression should be, 105 might be a little low. You might be better off to get the valves ground and guides replaced since you are already into it this far.
Post A Followup
: Re: Re: Re: Re: how can you tell if piston/sleves are
