Re: Water in air cleaner
Posted by Haas on September 02, 2003 at 17:44:24 from (12.65.54.85):
In Reply to: Water in air cleaner posted by Heath Boe on September 02, 2003 at 10:38:04:
Couple years back, I bought a Hebard Shop Mule which is a lowered and modified Farmall A. Drove it on the trailer and brought it home and drove it around some. Then went about replacing fluids. The air cleaner cup had only water in it! No oil at all. It ran fine that way and did not seem to notice the difference. I cleaned it with degreaser and then dried everything, put oil in the cup and it has not missed a beat since. I don't think water in your air cleaner will hurt anything. However, I have noted that these things do accumulate moisture and if not cleaned regularly the moisture in the bottom of the cup will cause corrosion and an eventual leak in the cup.
Post A Followup
: Re: Re: Water in air cleaner
