Re: Do not do !!!!!
Posted by Janicholson on March 30, 2009 at 15:53:50 from (199.17.6.128):
In Reply to: Re: Do not do !!!!! posted by Maniak on March 30, 2009 at 15:46:45:
The solenoid is correctly wired, and just fine.
If the Voltage reg in not marked for polarity, (and the sizes of the original cables in the Battery box were small to hot, and Big to ground) it can be setup to be pos ground (and probably was. I would jump the Bat terminal to the Arm terminal on the regulator with it not running (it will spark) then start it with a good 6v pos ground. JimN
