Re: Update on 450 PTO clutch
Posted by Ernie Bob on September 03, 2003 at 22:33:00 from (198.81.26.207):
In Reply to: Update on 450 PTO clutch posted by Bob K on September 03, 2003 at 07:05:54:
Bob;
I would like to add aword of caution here so maybe you don't face the same problem I encountered with my SMTA. When lining the PTO/Trans. input shafts into the clutch, enguage the PTO and turn it from the rear of the tractor while you line it up. I tried turning the flywheel while I lined it up and as I turned the flywheel the PTO shaft would also rotate and it did not line up as I thought and as I pulled the housing together I managed to bend the clutch disk.
Hope this helps!
Ernie Bob
Post A Followup
: Re: Re: Update on 450 PTO clutch
