Foam On Beer Is OK, But From My Radiator?
Posted by Capt. Minx on September 04, 2003 at 09:28:30 from (64.33.138.49):
My 460 Utility has developed a strange problem. When I first got the tractor it would overheat. After a radiator flush, new thermostat, new fan belt and cleaning the radiator fins it helped. It still tends to run a little hot (180 to 200 degrees) but does not overheat. I have used it for mowing the last 2-3 months with no problems. Now after running for a couple of hours, foam comes out the overflow and around the cap. THICK FOAM! (Like someone dumped a bottle of dish soap in the raadiator.) Like I said it doesn't overheat. Then it quits and then about an hour later it will start up again. What gives?
Post A Followup
: Re: Foam On Beer Is OK, But From My Radiator?
