Re: Cub Transmission Foam
Posted by Andy Martin on September 05, 2003 at 16:35:24 from (12.86.249.131):
In Reply to: Cub Transmission Foam posted by Kevin (FL) on September 05, 2003 at 11:37:27:
Water in the transmission grease, and too much fluid as well. Drain it and put in new to the check hole on the left side and you'll be OK
Post A Followup
: Re: Re: Cub Transmission Foam
