Re: Farmall H With Overdrive How common is it?
Posted by T im Kincaid on September 06, 2003 at 12:41:32 from (216.175.23.46):
In Reply to: Farmall H With Overdrive How common is it? posted by Dave Lee on September 04, 2003 at 20:09:28:
Dave, There maybe a few of them around but alot do not work. My H has a Heisler which is engaged with a cable .M+W was engaged with a control arm and also had a arm that disengaged the hydrualic pump because with the 9 speed engaged it doubles the speed of your pto and your pump which was pretty hard on pumps...fyi Tim K.
Post A Followup
: Re: Re: Farmall H With Overdrive How common is it?
