Re: super A serial number
Posted by Hugh MacKay on September 06, 2003 at 15:33:24 from (216.208.58.173):
In Reply to: super A serial number posted by john on September 05, 2003 at 15:56:08:
John: Each one of Farmall 100, 130 or 140 would have used the serial 4735 as they each started at number 501. A good way to check this out is by casting codes. I am not up on those but several regulars here on YT forums are. If you look at these they are in month and day by number and the year by letter. There is a bit of a blob in casting in between each numeral and the letter. The blob looks like the head of a screw. 100 was built from 1954 to 1956, 130 from 1956 to 1958 and 140 from 1958 onward. Those casting codes could be a year ahead of tractor.
The other item someone may know is engine serial numbers used it each tractor. These were not done in same manner as the letter series tractors. C-123 engines had their serial numbers and did not match tractor or even close.
Post A Followup
: Re: Re: super A serial number
