Re: putting a tac on an H or M
Posted by Dan on September 06, 2003 at 20:03:06 from (12.160.160.81):
In Reply to: putting a tac on an H or M posted by Wayne M Kittler on September 06, 2003 at 14:25:47:
I have considered the same thing on my smta. Problem with a regular tach is the scale, usually they go to 8 or 10 thousand whereas your farmall tops out at under 2. Puts the needle on such a small scale it is hard to tell where it is. JC Whitney has a tach listed that tops at 4000. Is electric and they say will work on 4, 6 ot 8 cyl.
Post A Followup
: Re: Re: putting a tac on an H or M
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
