Farmall Tractors Discussion Board
Re: Farmall 400 LPG
Posted by Harold H on September 25, 1999 at 05:11:06 from (207.244.54.150):
In Reply to: Farmall 400 LPG posted by robert searcy on September 21, 1999 at 17:35:39:
Robert,
I was going to reply sooner but my server went down Thursday and just came back up last night or this morning. I don't know production numbers for the Farmall 400 LPG, but in the Mississippi Delta it was the most common form of 400's sold. Out of each 10 sold I would guess we sold 1 diesel, 2 or 3 gasoline, and 6 or 7 LPG. LPG was the fuel of choice in the Delta in the mid and late 50's and into the early 60's. Both the Farmall 400 gasoline and the Farmall 400 LPG had the same 264 cu in engine but the head was different. The gasoline had 6.3 to 1 compression while the LPG had a completely different head with valve rotators, a different shaped chamber, and 8.35 to 1 compression. The Farmall 400 LPG was tested in Nebraska test #571 with 48.12 db hp and 52.36 belt hp. Corrected to sea level maximum horsepower was 49.54 drawbar and 54.11 belt. This horsepower was a little more than the gasoline model tested. It was built 54, 55, and 56. Serial numbers start; 54 501, 55 2588, 56 29065. Hope this information helps.
Harold H
Post a Followup
: Re: Re: Farmall 400 LPG
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
