M with no 5th
Posted by Josh on September 07, 2003 at 17:14:23 from (66.71.70.122):
I have a 1947 Farmall M that has seen a lot of use. It now jumps out of 5th gear regularly. It usually happens like this: I will be coming down a hill on the road, hit the bottom and as soon as the engine starts to pull again, either on level or up a hill it jumps out of gear. When you put it into 5th, you can put it in the 5th position but still not be in gear, uless you pull it all the way back. Is this most likely a worn shifter or is 5th gear worn out? Or something else? Thanks for the help!
Post A Followup
: Re: M with no 5th
