Re: Re: wheel bolts won't budge
Posted by JB on September 07, 2003 at 20:31:24 from (24.157.142.242):
In Reply to: Re: wheel bolts won't budge posted by Dave_Id on September 07, 2003 at 19:36:59:
Another method that I have used is:
Using a box end wrench with a couple of feet of pipe slipped over the wrench put about a 100 lbs of pull on the pipe and have a friend hit the head of the bolt hard with a hammer. Do not jerk the pipe just apply a steady pull. Jerking causes the bolt to snap off. Once the bolt breaks loose then work it out by a turn and in by about 1/2 turn while applying penetrating oil.
Good luck
JB
Post A Followup
: Re: Re: Re: wheel bolts won't budge
