Re: '52 Super A steering box gears
Posted by Al on September 08, 2003 at 06:28:54 from (205.244.113.10):
In Reply to: '52 Super A steering box gears posted by Gav-n-Tn on September 07, 2003 at 19:49:24:
Probably what is happening is most of your lost motion is from wear of the woodruff keys on the sector shaft. Check your gear teeth as mentioned, Replace the bearings and bushings, and find a good machine shop to cut new keyways on the gear and shaft. You can get a new gear and shaft from caseIH but they are super EXPENSIVE!!! and if you have the old square-end shaft, you gotta find a center steering pitman arm too.
Oh, and when you're done, pump it full of grease, not 90 wt gear oil. I got brand new bushings, shaft, and seals and it'll still leak a little oil!!
Al
Post A Followup
: Re: Re: '52 Super A steering box gears
