Re: Re: Re: '52 Super A steering box gears
Posted by scotty on September 08, 2003 at 09:40:44 from (199.231.49.128):
In Reply to: Re: Re: '52 Super A steering box gears posted by Shaggy on September 08, 2003 at 06:33:59:
Shaggy,
The bottom bushing that you are refering to is not easily replaced. That bushing was swaged into position, hope thats the right term. The outside of the bushing has a helical groove in it so its almost screwed into position. They used the same method on both wheel spindles and the large dia axle tube that pivots on the center pivot pin. I know this because I had to bore one end of the axle tube because of excessive clearance. Which I replaced with a brass bushing I made at work and pressed into position. Hope this helps!
scotty
Post A Followup
: Re: Re: Re: Re: '52 Super A steering box gears
