Yet another SMTA Generator question
Posted by Chad on September 08, 2003 at 14:22:34 from (206.230.0.170):
After reading up on generator questions from both archived posts and written articles in the technical section of this forum, I decided to take the generator apart on my SMTA to investigate the charging problem. The first thing I noticed was the fields wire inside the case was no longer attached to the stud terminal. It looked as though the previous owner tried to spot weld the wire to the terminal. My question is how should this wire and terminal be connected (weld, solder, mechanically fastened?). The stud terminal looks very bad so I thought I would replace it. Is this a very common part number?
Thanks a bunch for your help. I've gained a much greater understanding of the mechanics involved with the charging system because of the input from this forum.
Chad
Post A Followup
: Re: Yet another SMTA Generator question
