Re: '44 M question and Ford 3910 question for you
Posted by Tis on September 09, 2003 at 10:45:40 from (208.235.169.44):
In Reply to: '44 M question and Ford 3910 question for you guys posted by Big Red on September 07, 2003 at 21:44:08:
Have a 2001 New Holland 5610 that sets outside until my shed is built that had similar problems. After no use for about 3-4 weeks, the gears scraped when engagement was initiated. After consulting the dealer, this is a common problem with their newer tractors that set too long on the lot (no use). Solution: Jerk gear shift into low range and drive around (this might take 40 minutes) while repeatedly pressing in the clutch and aplying both breaks until the clutch breaks free. Put a piece of 2x4 wood under the clutch pedal as a preventive measure.
Recommend putting clutch ajustment back in original position before trying this.
Post A Followup
: Re: Re: '44 M question and Ford 3910 question for you
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
