Re: farmall H questions
Posted by Nebraska Cowman on September 09, 2003 at 17:45:39 from (65.172.143.89):
In Reply to: farmall H questions posted by Zach on September 09, 2003 at 08:59:45:
1. The H was badly leaking oil from the rear seal. We split the tractor and replaced the seal as well as all of the little gaskets that are in that area. I took the top and bottom pieces that the rear seal lies in to a machine shop and had the surfaces ground. We put everything back together and when the tractor heats up, it still leaks a fair amount although not as bad as it had. What else can I do to stop it from leaking? I don't worry too much about a little leak. Oil is cheap. 2. Fifth gear has a rattle in it and the shift lever seems awful sloppy, especially in reverse. I haven't tore into the transmission yet but can anyone give me any hints / suggestions as to what may need replaced / repaired? A lot of the shifters get loose where the pin holds the lever in the case. there is a round bushing that the pin goes through. sometimes you can replace the pin and or the bushing. if the hole in the case is worn you can drill it out and use a larger pin. 3. The ammeter is showing a slight discharge when the tractor is running. It is still the original positive ground six volt system and I just replaced the battery. What should I check? Is it distributer or magneto? Does the battery run down? the ammeter could be wired in backwards.
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
