Re: 30wt oil or HyTran for Hydraulics?
Posted by CNKS on September 09, 2003 at 18:35:48 from (207.178.96.211):
In Reply to: 30wt oil or HyTran for Hydraulics? posted by Darren in TN on September 09, 2003 at 10:40:12:
Do as Hugh says. Actually the seal doesn't blow. Since the shaft turns all the time the seal, or o-ring, depending on the pump, slowly wears out, while at the same time wearing a groove in the shaft. The combination results in a progressively worse leak. It doesn't happen all at once, but takes years. I suppose use of the hydraulics will force oil past a worn seal, but it doesn't actually increase the wear on the seal or shaft.
Post A Followup
: Re: Re: 30wt oil or HyTran for Hydraulics?
