Re: Re: Re: Re: Re: Farmall won't start
Posted by Randy in NE on September 10, 2003 at 05:21:35 from (216.58.237.20):
In Reply to: Re: Re: Re: Re: Farmall won't start posted by Jeff Daugherty on September 09, 2003 at 18:31:49:
You need to keep all cables hooked up. You may want to disconnect the ground cable where it fastens to the frame of the tractor. Take a wire brush and clean both the end of the cable and the area where it fastens to the frame. Have to have good contact. Shorting across the switch just means that you are jumpering across the two connection posts on the switch. This just makes sure that the switch isn't your problem.
Post A Followup
: Re: Re: Re: Re: Re: Re: Farmall won't start
