Re: ? for randy hall + others about compresion+fue
Posted by Steve - IN on September 10, 2003 at 14:01:57 from (12.222.30.13):
In Reply to: ? for randy hall + others about compresion+fuel posted by eric on September 10, 2003 at 11:41:03:
eric, To get max performance, you should match the octane to the compression ratio. Higher compression ratio needs higher octane; lower compression ratio needs lower octane for best performance. From recollection, a M has a C/R in the range of 6:1 to 7:1. The 85 octane at the pump is optimum for the 8:1 cars running around today. Actually, an M will want something around 70 octane, which you could get by mixing white gas or Coleman fuel in the tank. The downside of it is that max performance makes more heat in the combustion chamber than pump gas. The M is around 50+ years old, and probably has straight cast heads, no hardened exh. valve seats. So more heat causes more valve reversion. All in all, I'd use normal pump gas for convenience and add some two stroke oil, run it a bit rich, or some guys add ATF fluid; instead of adding expensive octane booster (when you really don't need more octane -- you're just trying to keep the exhaust valves cool).
Home
| Forums
Today's Featured Article -
Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
