Re: farmall H questions
Posted by carl on September 10, 2003 at 21:10:52 from (208.40.152.249):
In Reply to: farmall H questions posted by Zach on September 09, 2003 at 08:59:45:
Make sure the amp meter is not wired backwards. Did you try polerizing the generator? To polerize the gen. If your looking at the voltage regulator you need to get a jumper wire and touch the bat terminal to the gen terminal just tap the the jumper wire on the terminals youll see a little spark. You should also make sure the gen terminal on the voltage regulator goes to the armature side of the generator.
Post A Followup
: Re: Re: farmall H questions
Today's Featured Article - Talk of the Town: Repairin a Gas Tank - by Staff. This interesting discussion is from the Tool Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
