Re: Belt pulley removal from crank - c123 engine,
Posted by Gary-Miss on September 11, 2003 at 18:04:31 from (64.12.97.13):
In Reply to: Belt pulley removal from crank - c123 engine, HELP posted by RayP(MI) on September 11, 2003 at 17:57:09:
The pulley is force fit so, it has to be tight! You need to have something in there over the end of the shaft. That will make it easier to turn. I usually drill a couple of holes through the pulley and use a harmonic ballancer puller. I put nuts on the back. Sooner or later (usuallysooner) the three legged puller isgoing to break a chunk out of the pulley and ruin your day. It will come eventually. Good luck.
Post A Followup
: Re: Re: Belt pulley removal from crank - c123 engine,
