Re: changing clutches for engine and TA
Posted by Dan on September 11, 2003 at 21:25:09 from (12.160.160.81):
In Reply to: changing clutches for engine and TA posted by Brian on September 11, 2003 at 20:37:31:
I assume the 300 is similar to the SMTA. If so you have to split the tractor to change engine clutch. Front half isn't too bad as you can make A frame split stands. Back is heavy. To do TA clutch you have to split the middle section out also. Not bad if you have a good hoist or a loader. Whe I split my smta I took it apart just ahead of the transmission first as I needed to put in a new coupler on the pto shaft. I decided to go ahead and fix ta so I took the middle section out next. It is heavy but handled it with a loader. It helps to have either a I&T manuel or better yet an IH repair manuel, parts book also helps. I used long bolts with heads cut off of same size as front and rear unit to line up parts when putting back together and taking apart.
Post A Followup
: Re: Re: changing clutches for engine and TA
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
