Re: Farmall A not charging
Posted by Gary in MOOzarks on September 13, 2003 at 03:06:29 from (64.240.21.169):
In Reply to: Farmall A not charging posted by Mark R. on September 12, 2003 at 20:00:29:
Depends on what kind of altenator he used (one wire or 3 wire with an internal regulator) or one with an external regulator. You can take it off and take it to your local auto parts store and they can put it on a machine to make sure it has output. Then you know its not a burned out diode inside. There is an article on YT by Bob Melville on step by step 12 volt conversion for the farmall M that is excellent. Also has a good diagram. Good Luck
Post A Followup
: Re: Re: Farmall A not charging
