Re: Re: Re: Re: How to inspect Farmall M Clutch As
Posted by Dave Carney on September 13, 2003 at 09:06:21 from (67.9.108.241):
In Reply to: Re: Re: Re: How to inspect Farmall M Clutch Assemb posted by Haas on September 13, 2003 at 06:10:53:
Haas:I have removed the Lift pump and the race that the throw-out bearing is on, is all eaten up. What is that part? While I am in there we are going to replace the clutch plate and pressure plate, throw-out bearing. Do you have a recommendation, where we can get all these parts. Some place that is reasonable and reliable. Would you know the part #s? Any Help would be appreciated. Do you have an E-mail Address? Best Regards Dave Carney
Post A Followup
: Re: Re: Re: Re: Re: How to inspect Farmall M Clutch As
