IH 504 problems
Posted by Tom on September 23, 2003 at 16:25:58 from (65.166.178.122):
I have 503 industrial with a front end loader and back hoe I have about 300 hours on a engine
rebuilt. I has set for a couple of years. I decided to sell it this year but while getting it
running I had a lot of blue smoke and a knocking in the engine.
I pulled the valve cover and I found two bent push rods, and one missing push rods.
I replaced them but could not find the missing push rod in the upper end. I also poured some
Rislow over the valves and re-adjusted the valve lash, and it was smoking a lot less.
but still smoking.
I pulled the Oil pan, and found it had spun a rod bearing to little pieces and I have
another rod that's a little sloppy on the crank. It also acts like it has stuck rings.
Right now I guess I would be looking at a used crankshaft, lower end rebuilt kit at least one
connecting rod. Plus some seals on the rear axles
Would I be better off?
1. fixing it
2. calling the junk yard and having it hauled off.
3. parting it out and making every one who need 504 parts a really good deal
4. Filling the wash out with the tractor instead of using the tractor to fill the washout.
At the moment I amd strongly in favor of 4.
Post A Followup
: Re: IH 504 problems
