How are you using the choke? A cold engine may need the choke on about half way for a while until it warms up. Pulling it on & off is not the right way. As it warms up, you will notice black smoke and it will start to gallop. Then give it enough air to smooth out. Low compression takes a richer mixture to fire.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
