Farmall Tractors Discussion Board
Re: Tread adjustment on a Farmall M
Posted by Village Blacksmith on September 26, 1999 at 21:38:51 from (152.163.197.203):
In Reply to: Tread adjustment on a Farmall M posted by Rod H on September 26, 1999 at 19:10:13:
Had the same problem on an H last summer. Look at the axles and see how much the wheel can be moved in. If the wheel can be moved three or four inches, it may be necessary to only move one wheel. Jack up one axle and block it up securely. Farmall is pretty easy to move. Just loosen the four big bolts on the clamp and push it in to the desired location. Push on the wheel and bump it with a big wooden block. Don't hit it with a hammer. The laws of inertia etc. get in the way.
Post a Followup
: Re: Re: Tread adjustment on a Farmall M
