Farmall Tractors Discussion Board
Re: farmall 340 hydraulics
Posted by Charlie V on September 26, 1999 at 22:18:41 from (207.202.174.194):
In Reply to: farmall 340 hydraulics posted by Eric G. Mann on September 25, 1999 at 19:08:50:
I'm sure you check and double checked that your hose's are all on correctly. It sounds an lot like pressure build up is the problem, thus something is backwards. Did that once on my 340 and acted the same way when working with the front loader. Also had a problem with low hyd fluid, replaced the pump and hoses, hyd's would not work at all, put ten gallons in, though it was enough, it wasn't, had to put in another 5 gal to make up for filters, hyd lines, pump, cylinders. Hope this helps ........ :-)
Post a Followup
: Re: Re: farmall 340 hydraulics
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
