Re: F-20 Rear Axle Leak
Posted by Jim on September 25, 2003 at 01:38:26 from (63.71.111.81):
In Reply to: F-20 Rear Axle Leak posted by The Red Barron on September 22, 2003 at 00:59:12:
Let me know how much work it is. I need to undertake the same problem on my '36 F20. I tried to plug the leak from the outside with no luck. Jim
Post A Followup
: Re: Re: F-20 Rear Axle Leak
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
