Re: TA - High or Low - In or Out?
Posted by RAW in IA on September 25, 2003 at 11:00:42 from (12.216.217.196):
In Reply to: TA - High or Low - In or Out? posted by Brent in Iowa on September 25, 2003 at 10:27:45:
If everything is adjusted right, you are not hurting the TA, but the high side is straight through and not really cuasing any wear n the planetaries, as is happening on the low side. We used to run our 350 on low side quite a bit of the time, plowing and discing, and never had any trouble with it. Just rmeember to keep it adjusted right, and don't eas the lever in or out. Squeeze the handle and let it go. Also, change the hy-tran in the transmission regularly to extend the life of the TA.
Post A Followup
: Re: Re: TA - High or Low - In or Out?
