Re: Installing head gasket on Farmall A
Posted by Jonathan Mirgon on September 25, 2003 at 16:03:49 from (205.208.129.29):
In Reply to: Installing head gasket on Farmall A posted by Gerald on September 24, 2003 at 19:21:12:
I had trouble getting mine to seal dry ? And had to remove it again due to water in the oil. I learned the hard way, The solution for me was to use some brake cleaner on the head and block surfaces, This takes off any grease or oil and also evaporates quickly. Then use the permatex cooper gasket sealer that is in the aerosol can and give both sides of the headgasket a good coat or two. Yours may seal ok dry, but in my opinion its best to use the sealer, its kind of like insurance.
good luck ,
Jonathan
Mirgon
Post A Followup
: Re: Re: Installing head gasket on Farmall A
