SUPER a NEEDS FULL CHOKLE
Posted by Mike Root on September 26, 2003 at 17:58:51 from (64.12.97.13):
I recently got a 54 Super A from my father in law. I bought it from his deceased brothers estate. It starts and runs fine on full choke, It will die if you move the choke lever. I have replaced plugs and points, It's a twelve volt system. I've boiled out the carb and the floats are high enough. There is no filter in the carb elbow but fuel pours out of the fuel line when it's disconnected. There are also no vacumn leaks.
I'm replacing the coil this weekend as I've never checked the spark with the engine running. The voltage at the battery is 14+ volts when it's running. Timing and point gap are spot on.
Any suggestions?
Mike
Post A Followup
: Re: SUPER a NEEDS FULL CHOKLE
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha ... [Read Article]
