Re: Flow Diverter Valve for IH 3414 Backhoe/Loader
Posted by Wardner on March 30, 2009 at 17:28:51 from (4.154.242.65):
In Reply to: Re: Flow Diverter Valve for IH 3414 Backhoe/Loader posted by Phillip Cagle on March 30, 2009 at 12:27:01:
Ports labeled "in" and "aux" are 1" o-ring. A number 16
Port labeled "Res" is 1/2" o-ring. A number 8
Port unlabeled is 3/4" o-ring. A number 12
O-ring hydraulic fittings are frequently used on IH products of this vintage. The thread is a standard machine thread as used on a bolt. The entrance to the bore is chamfered and is where the o-ring is compressed by the fitting or hose end to form a seal. Your tractor probably has a bunch of this style hydraulic fitting. However, it is possible that it also has pipe threads and JIC. It really doesn't matter as adaptors are available to change anything to anything else.
I want $150. That will include postage. If interested, send email to wardner at peoplepc dot com using the correct address protocol.
